If everything else is done right, you shouldn't need the sealant. As a last resort, it works.
If it DOESN'T work, you may have an abused head (they typically leak at the top, when they leak).
Also, there is a possibility that the front and rear may have slightly different gaps, so measure carefully and use the closest thickness seal for each one.
