True statement on the calipers downtown, sorry I missed that...so now I am thinking after your PM that said it has a digital insturment cluster that was first on 83 Aspencade's you bike has parts from a mix of years. Not a bad thing, just might make picking up parts a trick.cxman said:its a 82 and early one at that
forks are early style single pot early style rotors to
83 had twin pot calipers and trac antidive forks
cxman said:hey downtown dont laugh but i took a cx500 fender and 2 minutes of hole stretching with a burr and it fit nice on my 83
I love that fender and I might just use that, thanks...
Hoosier Daddy said:True statement on the calipers downtown, sorry I missed that...so now I am thinking after your PM that said it has a digital insturment cluster that was first on 83 Aspencade's you bike has parts from a mix of years. Not a bad thing, just might make picking up parts a trick.
So tell me this, your Insturments should have a gear indicator on it. Does it work for all gears? The neutral switch was became a "Change switch" and if I remember right on the 83 Aspy shows 1 N 2 3 4 5 on the display. On an 82 or older with this cluster, I don't think this would work properly unless the neutral change switch was swapped out as well.
You were quoting Murray but he won't mind. The cluster shows all gears and it does work.
Chicagomike said:Is there a link to the original build?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
1980 The frame serial number began SC02-2000040 and the engine serial number began SC02E-2000047.
1981 The frame serial number began with the new style used throughout the motorcycle industry and common to the automotive industry: 1HFSC0207BA100001 and the engine serial number began SC02E-2100002.
1982 The frame serial number began with 1HFSC0205CA200101 and the engine serial number began SC02E-2200028.
1983 The frame serial number began with 1HFSC020XDA300101 and the engine serial number began SC02E-2300012.
downtown809 said:There is a link to a 78 build but it never went anywhere as I couldn't get it running so I took a step back and realized it needed to be with someone else.
Chicagomike said:I guess I ment is there a build thread to the bike you're copying?
