Thanks adventurco. I was excited to get a lathe for flashlight work actually (odd I know), but I really haven't used it much. I have yet to do any threading or anything that requires any skill. It's nice to have to turn down various parts though and machine simple spacers.
So after ordering "amber" LED turn signals from Ebay that were basically red, I ordered these from Super Bright LEDs...
License plate LEDs
https://www.superbrightleds.com/moreinfo/led-wired-bolts/miniature-led-license-plate-bolt/1685/
Small LED strip
https://www.superbrightleds.com/moreinfo/led-light-modules/am-series-miniature-rectangle-accent-light-black/25/
Flasher relay
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/lf1-s-pin-universal-motorcycle-electronic-flasher/193/841/
I decided to use the first ones for front turn signals. They are tiny, and really aren't that bright, but they should do the job. I should have taken a closer up picture as they are hard to see. Headlight isn't mounted yet, need to machine some spacers first. Oh, and I will definitely be making a DIY brake line to replace the one you see here.
The flasher relay seems to work great.
I bought a Trail Tech Vapor dash unit along with the shroud for indicator lights. I need to make a mount for that and wire it up which shouldn't be too bad. Maybe I'll actually get to ride this damn thing before Winter comes...
