CX500 Street Tracker
Need to see your good welding if that is the quick stuff!
Nice plan, subscribed.
I see a tire changer plate and pin and Jersey has an idea with the swap out buff station... lots of stuff to keep the shop clutter down... Shop Smith for metal works!! Porta band saw stand?? Need a power strip close by!!
The multiple tool swap was the plan for this long term.....I just needed to get around to making this and now I can make other tool holders
Tune, there is a power outlet directly behind this on the wall
I know you got tires on the way but I noticed this on the shinko 705's this morning
Alright, managed some progress today with mounting the lower link to the frame. I did try and use what was on the CX650 Euro frame but just couldn't get it to work right so I needed to make my own. I had some pieces order from my metal supply the other day and then also turned out 2 pieces on the lathe
Well you can see it in the pics below
Next is the upper shock mount on the spine, should be done tonight or tomorrow then I can get onto the seat frame
Thanks guys, seeing that others are interested has gotten my mojo going to get this build done
Now onto todays work........so I managed to get the upper shock mount built and welded on
Now I need to tackle the area where the seat frame used to go and prep it for foot pegs and a rear master cylinder
it was very utilitarian and quick + if the bolt ever breaks the shock gets caught in the upper mount
