SR250 brat
xb33bsa said:
bouncing on it is nothing at all like hitting a bump in the road
the rear fender is a goner the way it is now
maybe you have it way oversprung ? it should be nice and cushy
you clearly dont understand suspension geometry because what you have done is increase the leverage quite a bit over the stock set up as well as increase the travel x 2
Thank you for your input and I'll keep that in mind
just trying to save you some grief
pull one shock off and ratchet strap the shock side down you will get an idea of the huge amount of wheel travel that you have
I'll give that a try. Thanks for the help
