StinkBug
I've never been able to get the idle on my CB750 quite right and now it's just getting me confused. Here's where I'm at.
The idle adjuster screw is turned all the way out, but the idle is still quite high. What's more concerning is that the left pipe is popping a LOT and now there's actually fire coming out. When sitting on the bike you can hear the right side firing smoothly, but the left side isn't really making any noise til you give it a little throttle. Off idle the bike runs great. Sometimes there's a little stumble while easing off from a start, but once you're on the gas it pulls hard and runs smooth. There's just a lot of popping on decel, and when standing at idle. Pretty much any time the throttle is closed.
Up til now I had attributed this to the fact that the carbs had never been sync'd. Well tonight I finally hooked up a sync tool and got em all dialed in. They were all over the place, but now they are pretty good. The bike seems to idle better, and doesn't try to randomly die anymore, but the popping is just as bad if not worse. Also now the idle is higher, and since the adjuster is out all the way I'm not sure how to get it to go down.
What has me really confused is that it only seems to be the left 2 cylinders that are causing problems, and only at idle. the right side seems to be running quite smooth, even though all 4 carbs are adjusted the same and are now sync'd. I'm now unsure if it's a carburetion thing, or if maybe the left coil is starting to go and is just weak at idle.
Here's a video of the bike at idle right after my test ride this evening. I'm open to suggestions. Thanks!
http://youtu.be/VLLtjmlTyGs
EDIT: Guess I should add the bike specs. It's a 1980 CB750F Supersport, DOHC. Recently got new rings and shimmed the valves. Internals are otherwise original. Pod filters, and straight through mufflers on the stock 4 into 2 exhaust. The left and right exhaust pairs are not linked together.
