Have you seen or done the stock boxes for comparison? I'm curious how the two look next to each other.
Are you sure this is right? Swirling is turbulence. In an intake manifold, the function of swirling isn't increased flow, but better distribution of fuel in order to create a more homogeneous fuel-air mixture. I realize we're talking about the inlet side, but I wouldn't think the physics would change.Sonreir said:This will help to promote a swirling effect which, in turn, may increase flow.
mechdesign2k4 said:Well your inspiring me to fire up solidworks and the 3d printer at work.
mdturner said:I'm assuming you didnt model those carbs from ground up, where did you find the .sldprt files for those?
Oh how I wish I still worked for a company that had a 3d printer!mdturner said:I just got into motorcycles but I'm definitely going to 3d print all kinds of brackets and check things out so I can cnc everything. Ah the perks of working for a 3d printing company!
Bucky685 said:Check out www.grabcad.com
