coyote13 said:Really makes you wish Powroll were still kicking around huh?
crazypj said:62mm won't fit in stock liner, 61mm is max (been there, done that )
You have to bore the 125 liner out of cylinder as they were cast in place
crazypj said:You have to machine top of CB750 piston.
Use same spec as 750 piston in CB500f. (same bore, 56mm)
Need access to a lathe or milling machine
It will not be possible to beat the price of eBay kit
XL185 cylinder is too tall for 125 crank
Lifan may be pushrod motor not OHC?
