Jramos13
Ok so i finally finish my 1978 XS500E top end rebuild, and was adjusting valves last night, the manual does not state what the piston position should be, i adjust them in the V mark at the advancer plate, at that postion all valves are closed, Thats the postion it says to put the crank while the dots on the cams are aligned with the marks up top.
So do i need to do TDC for each piston and adjust the corresponding valves or is it ok at the V mark?
Thanks!
Thanks!
