MattCB750OT
So unlike most or all of the posts that I found for this, I couldnt find any that have the "filled in" passenger triangle.
So I am thinking of drilling a hole, then welding the mount in that triangle, near the top front. An inches behind and a couple inches up from the brake pedal bolt. Im using Tarozzi Universal. The triangle is two sheets of metal (certainly not 1/4"), spaced apart. The "mount" would be a coupling nut about an inch long.
Would this essentially work? Should I strengthen the triangle? I could weld a "back plate" behind the triangle, or open it up and weld it behind. It should be strong enough since it holds the exhaust and passenger pegs, but Im worried about the coupler in the thinner sheet metal not twisting or bending. (I think I am answering my own questions as I write this out)....
Thoughts?
Thoughts?
