crazypj said:If you read between the lines on the last several posts, i's pretty obvious it's out of his pay grade and will be cheaper in the long run to get 'professional help' (lot of people think I could do with some ;D )
hillsy said:Don't forget he's already hit the thing with a BFH. God knows what's happened inside the gearbox.
Maybe cutting it off and replacing will be the best option in the long run.
mydlyfkryzis said:I believe I have a CB360 Shift lever too...Let me check....
If you can't straighten yours, we can work something out....
mydlyfkryzis said:I doubt he did internal damage. It would hit the clutch basket of the other side. He may of bent the pawl too.
But the trans doesn't really see any forces from that particular shaft, so he may be lucky.
jr75cb360 said:Rich Ard I didnt have my motor with me at the time(since this shop is rarely open). His advice was a pipe and some heat.
And I think my terminology may be wrong but I have never hit this shaft with a BFH
But when the "gear selector" was on this shaft^ I did try to move the gear selector up and down with a hammer but it wouldnt move.
And let me know what we could work out on this shifter shaft
crazypj said:That shaft isn't bent enough to make any difference
