JohnnySomersett
Active Member
Right, so I had a previous thread about my engine going bang the other day, and the good folks here convinced me it was a better idea to get stuck in myself than pay someone too much money to do it instead. So far, I'm glad they did as it's been pretty easy!
But I'll start at the beginning....
So, I went to work getting the engine out of the frame. I already had the gas tank off and some other bits disconnected so it was just a matter of unplugging all the wires, dropping the pegs and brake lever off then unbolting and lifting out:
So now it was on my bench...
Now, here's where it gets interesting and very apparent why it stopped working:
...now, I know my knowledge on bike engines is small, but experience with old cars tells me there should be a chain there somewhere!! :
Valve head off
...everything looks okay there
No piston damage that I can see of. Just a load of carbon which I expected:
The bit of metal sticking up between the cylinders, bottom right, doesn't look right, and feels sharp on top. It that damaged?
Cylinder head was on fast, and I unfortunately broke a tiny piece of a cooling fin off easing it, but all the cylinder walls look sound
Still, I got it off and the pistons are fine:
I think this thing is the cam chain tensioner, it looks a little worn... would you agree?
...And here is the offending article. Little bastard...
SO
Things I definitely need include a new cam chain, I'm guessing a fresh tensioner too as that looks a bit knarled-up...and a gasket set of course. What is the likelyhood of the bottom end being a big hot mess? Any advice? There's obviously a piece of chain in there somewhere too which doesn't fill me with much joy.
Help on what you'd recommend doing next would be greatly appreciated
Valve head off
SO
