I have an observation based on knowledge acquired from years of car racing, plus having built a few intake systems from scratch myself.
The carb size is really irrelevant until the motor rpm exceeds the carb's flow capacity. It'll run good up to a point then flatten out if the carb is too small. It will bog badly and not respond to throttle quickly if it is too big.
On the intake design....D4N63R is right. Too long. A couple things need to happen. First, and most importantly, it needs a carb with an accelerator pump. The idle may in fact be too rich, but it does a lean pop and back fire because there is a "hole" in the fuel delivery. The time it takes between crackin' the throttle open and the time fuel actually flows. Once you crack the throttle, manifold vacuum drops and it stops pulling fuel.
The "BigThing" about an intake that long. Fuel puddling and separation. Until it gets good and hot, the fuel will collect on the sides of the intake runners and simply make a puddle. If you look at virtually every intake manifold on a production vehicle with a single carb feeding multiple holes, the manifold gets heated. This keeps the fuel vaporized so that it is available to burn.
In the motorcycle world, Harley's have a single carb. BUT, (big hairy but) the intakes are short and the carb has an accelerator pump. You can probably make it work with a carb that doesn't have an accelerator pump, but the intake is gonna have to be short. As short as possible. And the carb size should probably be close to what size would work on it with individual carbs. It will ALWAYS have a off idle bog tho.
Just my opinion based on 40 years of building and racing cars
