berck said:
Compression: more compression sounds grand, but I opted for stock compression pistons very deliberately. Pre-rebuild, I got detonation when hot under full load even with 91 octane gas, and seriously retarded timing. I'd been adding toluene on hot days to prevent this, which worked fine. After disassembly, it became obvious the detonation was likely because of the huge amounts of carbon caked on the top of the pistons.
Anyway, that said, there was no way I was going to go to 12:1 pistons. 12:1 pistons need race gas, and a bike that I can't fuel at the pump isn't very useful to me. Also, the cam I used is not a full-out race cam. Description: "TT style performance. Strong mid-range, added top-end."
You came here for advice so it would be helpful if you listen to it . . Your comment shows that you are completely unfamiliar with how elevation affects compression . . First of all, 12:1 pistons probably do NOT need any more octane than 91 at nine thousand and two hundred feet
You loose around 4.7 to 5 psi of cylinder pressure for every 1000 foot increase in elevation, so the math is simply 9 x 5 = 45, so you subtract that number from whatever your compression would be at sea level and that is around what it will be at 9200 feet . .
A performance engine has around 170 psi and can run on 91 octane . . When an engine gets to 135, it is fairly weak . . When it gets to 115, it may or may not even run above idle.
I general, the bigger the cam, the lower the compression becomes because it closes the intake valve later.
berck said:
Bore-tech recommended the piston/cam combination for a more powerful street bike, and they have experience with them working together.
If you told them you were at 9200 feet and they told you to use standard pistons, they are retards and obviously have zero experience with that combo or any other one working at that elevation.
If you told me you were at 9200 feet and wanted to buy stock pistons for it I would not have sold them to you.
berck said:
I'm perfectly willing to increasing the timing advance once I get things running, assuming this doesn't cause detonation on 91 octane fuel (the best we can get at the pump in Colorado).
You wont know what any of the changes will do until you try them as DOHC said, however, in general, the lower your compression, the more timing you need.
berck said:
Spark plugs: I'm using the stock BG8ES for now. Hoping I get the carb dialed in to get rid of the soot on the plugs, but after it's running, I'm certainly willing to play with different plugs. I was using colder plugs before the rebuild to help with the detonation problem.
How did the plugs look prior to the build?
It could have been a bit rich but still run ok.
Put in one step hotter ones now, not after you jet it . . If you get your compression back up to where it should be, go back to the stock heat range . . Also, keep in mind that at sea level, you are running in air that might be around 70 degrees . . My guess is that you are running in air that is maybe 50 and less at 9200 feet.
berck said:
I disagree that it's not possible to carbureted vehicles run up here.
Read my post again . . i did NOT say it is impossibe to run a carbed engine at 9200 feet . . Lots of people do it every day.
berck said:
I put over 10,000 miles on this bike between 6,500-9,200ft with no problem
You're quotes below contradict that statement.
berck said:
I want it to look stock, just have a little bit more power.
I basically wanted enough power out of this rebuild to climb the mountain pass on my commute faster than 55mph at redline in 3rd. Or go faster than 65mph when there's a 25mph headwind.
It has a problem, otherwise you would not be trying to make it faster and your problem has always been low compression which you did absolutely nothing to fix, and in fact, you actually REDUCED your compression with your bigger than stock cam.
FACT - Your bike will always be a slow ass pig until you substantially increase your compression . . there are no ifs, ands or buts.
FACT - You will go a little faster if you install numerically higher gearing such as installing a front sprocket that is one tooth smaller than your current one . . If you want to make a smaller change, install a rear one that is 2 teeth bigger.
