Tune-A-Fish said:
Seems on A-1 you opened it 50 thousandths so you should be somewhere around .080 or loose. I get my calipers out and make the math simple... Probably not right but I'm self taught. I check with a feeler and measure the feeler to get thousandths then add or subtract what I need to adjust to spec then select the shim based on thousandths only... If that makes sense try that. If not just wait someone will be along shortly.
The clutch if stacked adjusted and clocked at the arm to 90 you should be good. The problem for me or anyone is we can only go by your input.
Even though the shims are metric, I always check clearance with an inch feeler gauge, those numbers are for a metric feeler
The GS range only use 0.001"~ 0.003" and if you make them larger they make a load of noise
GS 850 can be loud anyway as Suzuki F***** up machining cam thrust cap, don't have it running on sidestand as nose of cam can hit edge of shim/bucket which 'flicks' it sideways plus spins bucket in bore
It's best to mic the shims your removing as stock come in some pretty odd sizes (which is great for getting clearance perfect on 'race' motors)
As exhausts are tight at present you will need to set them at least 0.001" 'loose' although +0.002" will also work well (the valves WILL tighten up again as they re-bed into seats, I always used clearance of 0.004"~0.005" if bike was hard to start when cold and ran OK when hot)
Oh, the smallest shims Suzuki or aftermarket are 2.20mm, I should have some down to 190 (if my brother hasn't tossed them)
I had to have them specially made, they are not hard all the way through but case hardened to 0.020" depth (I had a couple of genuine Suzuki one's cut up and analysed about 30yrs ago by a Ford engineer working at Bridgend Engine Plant)
If everything is set up and working right, the clutch can be pulled with just a pinky, heavy duty springs make it only slightly more difficult to pull
