1970 VW Bus - Westfalia Resto
Blasty things happened today.
Well, I got home and started cleaning everything off. TONS of holes in the floor which didn't surprise me that much. What sucks is the guy missed a ton of areas on the undercarriage. He's "asking a guy if he can come out tomorrow, no promises."
I'm pretty pissed. I can't paint over this shit, I wanted to have all the bare metal primed tomorrow. Hopefully he makes it right. The one saving grace is that I haven't paid yet.
This weekend was rough, but productive. In the 90s with a heat index of over 100 makes not so fun work out of cleaning sand, prepping, and spraying.
After work Friday, I got home and started cleaning all the sand out the bus. Well I found a ton of areas that the blaster missed, and I was super pissed about it. I called him back and he ended up coming back out Saturday morning to hit the few spots that were missed. Overall the job was about 6/10 quality as a lot of areas were not done as thoroughly as I would've liked. Oh well, its done and paid for now.
So Saturday morning after they came back and finished up, I got to work. Wet blasting sucks. Sand caked to everything. 12 hours on Saturday prepping any missed areas and cleaning. I sprayed everything down with Ospho to kill any residual rust and flash rust that appeared.
Sunday morning I did a final clean and wipe down with acetone, then sealed all the bare metal with Epoxy primer.
Then I decided it would be a good idea to paint the seat frames (which I also had blasted) with a brush...so I spent the rest of the day doing that. I found one broken spring on the drivers seat in a spot that had rotted out. I think I have a plan to fix that but any suggestions are welcome.
And last but not least, late last week my rebuilt 34 PICT-3 came in from Tim at Volkzbitz. I'm thoroughly impressed. Here's a little before and after.
Thanks fellas. I was pretty down on this project after the whole sandblasting debacle, but now that I’m past that I’m feeling motivated again.
Tonight I worked some more on getting the nose ready for the transplant. I’ll post some pics on that later.
Also, 3/4” galvy conduit from the big box stores is a damn near perfect match for the main harness conduit. The blasting blew some holes in the original one. I got a 5’ piece for $4.50. Be sure to grind off the galvanization before welding. I bent a tiny bit of a crown in it so that any water will drain out the ends.
Yesterday after work I knocked out a big dent at the front of the roof. It still needs a bit of work I think but we'll see after I get the rust cleaned up and some primer on it. Are the two holes higher up on the roof are supposed to be there (visible in second pic)
Then I rough cut and formed a small patch for the back side of the roof, where one of the luggage rack screw holes rotted out. It fit up really well and I took my time welding, but the metal seemed to pull in a little bit after it was all said and done so there's a bit of a low spot. I'm thinking I may want to keep my gaps a bit smaller to avoid this in the future.
I had last week off to work on the bus, and do some work on the house to get it ready for the market.
Decided to tackle the rear parcel shelf and the rotted corner so that I can get the engine bay buttoned up and ready for paint. Unfortunately I ended up having to cut out more metal than I had donor metal, so I had to piece it together with 7 pieces. The "before" pic makes it look better than it was, after blasting the deep pits between the ribs were probably as thin as paper. Pretty much hated myself during that entire repair. The interior corner went in really well, it was cut a bit short by the fuel filler so I had to fabricate some pieces to make it a bit longer, and then fabricate a small piece to patch up the shroud around the filler neck. Skimmed on some Dura-Glass, sanded and shot with epoxy primer. I also seam sealed the back side of the weld and primed the "roof" of the engine bay, got the gas tank shelf all patched up and sealed as well.
Parcel Shelf After Blasting:
Parcel Shelf Welded up:
Interior corner before, there was a HUGE ass mouse nest inside the cabinet. Gross:
Corner welded up and filler neck shroud tacked in. I replaced the whip on my MIG a few months ago and apparently I was too rough on the replacement. It started leaking gas, and I accidentally left the tank shut-off valve open one night and it emptied out my tank. Figures, the one time I've ever NOT closed off the tank, I have a leak in my line. I need to address that cancerous area above the corner I replaced. I welded up some holes but its pretty gnarly. I may just weld up the few more pinholes that popped up and slather some POR-15 on there. Those riveted sheet metal covers go over that anyways, but I do want it to be solid.
Had to refill my argon bottle and then got everything welded up, filled and shot with epoxy primer. I got pretty impatient on those long ass weld runs on the parcel shelf, so its a little bit wavy but it's going to be hidden by the "bed" so I'm really not worried about it.
Later in the week I powder coated and welded in the "mud flap" pieces I made forever ago. Just need to scuff and seam seal them up.
