I had a connecting rod bearing go bad. I'm at a stand still as I'm having trouble locating locating all the marks so I can determine which color code bearings to order. I located the letters on the back of the crank case by the pry gap and the letters stamped on the crankshaft lobs and some marks on the connecting rod. Below is what I found.
Back of case: A B
B A A B
Crank lobs : B A C A
Con Rod Marks: 4.41 1
I'm sure i've got what I need for determining the color code for the Crankshaft and balancer shaft bearing selection, but I'm not sure I have the numbers for connecting rod bearing selection. Is the lone #1 on the connecting rod one? wheres the other number so i can cross reference and determine the color code. Pictures and translation of this would be a huge help. Looking to get past this hold so I can do a valve job. Thanks.
-Johnny Crash-
Back of case: A B
B A A B
-Johnny Crash-
