So I've got a major oil leak between cylinders 1 and 2 on my bike that coincidentally started after my family's mechanic tried to fix the leak in the valve cover that I couldn't solve. He removed the cam caps to find out they were stripped out and heli-coiled them for me again. On the ride home I discovered a major leak coming from between cylinders 1 and 2. I am 99% sure it's not the head gasket as the leak seems to be coming from below the head gasket and at the rate the oil is coming out I'm almost positive I could see it if it were coming from the head gasket. It's running down the second or third fin down from the head gasket and dripping down onto the crank case.
Could it be coming from that oil line that runs up between the cylinders? I've attached some pictures, but I can't identify the exact source because the frame and exhaust are in the way. Any ideas from some of the experts?
http://imgur.com/oLCEUeQ
