huck_finn
I was changing my oil over the weekend (first time I have ever done it), and when I pulled the right crankcase cover off there was a bushing/washer that fell into the cover. I have searched all over the web trying to identify where it goes, but have had no luck. Any ideas?
I took the kick-start arm, foot peg, and right exhaust off before removing the cover. All of their parts are accounted for. The only work I did when changing the oil was pulling out the screen assembly and the oil filter cap. No other parts were touched. Here is an image of the mystery part in the cover (for scale) and the oil pump idle gear. I apologize - I can't get the picture to rotate. I thought it might have come from the idle gear, but the case won't fit back on with it located there...plus it seems to already have the washer on the idle shaft.
I also noticed that crack in the case...do I need to be concerned about it? It is a small dent from the outside...and doesn't seem to have broken through (as far as my flashlight could tell).
<img src="http://www.midnitegin.com/wp-content/uploads/2016/11/2016-11-20-21.48.09.jpg" alt="" class="bbc_img">
<img src="http://www.midnitegin.com/wp-content/uploads/2016/11/2016-11-20-21.48.48.jpg" alt="" class="bbc_img">
