www.Moto-Madness.com
Author Topic: Welcome to Sparck Moto  (Read 35976 times)
Online Sonreir
  • Moderator
  • Oregon
Re: Welcome to Sparck Moto
« Reply #10 on: Oct 29, 2013, 20:11:36 »
Well done Matt, looks great. Wish you the best of luck with it.
Thanks, Perry!
Congrats Brother and I wish you the best of luck!!! Retro Moto is now offering wiring harnesses,btw.
Thanks, Junior.  If Retro Motor's harnesses are anything like their other products, they should be pretty kick-ass.  ;)
'Prototype'  ;)
Looks awesome, Pete.  What kind of clearance is there between the points plate and the rotor?
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline crazypj
« Reply #11 on: Oct 30, 2013, 14:24:45 »
It's 'adjustable' while I still have it here.  ;)
At present, 7mm
Outside diameter is 2.250", points plate is 2.4"
Best thing I ever overheard
Brian Morgan, 1982
Online Sonreir
  • Moderator
  • Oregon
« Reply #12 on: Oct 30, 2013, 14:31:11 »
I see how it's setup now.  I always envisioned it to be behind the points plate, closer to the head.  This should work, too, though.
Online Sonreir
  • Moderator
  • Oregon
« Reply #13 on: Oct 30, 2013, 14:32:29 »
Also... maybe 5mm of clearance might be better?
Offline crazypj
« Reply #14 on: Oct 30, 2013, 14:35:24 »
It would be easier to make from thinner piece of material - less waste, less machining, just make a spacer to get to end of cam post so it clamps down
I think there would be enough clearance, I'll make a 'short' one to check.
Rotor only needs to be slightly thicker than magnets being used so I guess 4mm would be plenty?
Brian Morgan, 1982
Online Sonreir
  • Moderator
  • Oregon
« Reply #15 on: Oct 30, 2013, 14:39:42 »
Definitely plenty.  The test magnets I'm using are 1mm thick and 3mm in diameter.
Offline JustinLonghorn
« Reply #16 on: Oct 30, 2013, 14:49:45 »
Righteous.
Into The Sunset, CB750 build
TT500 the Animal
Offline crazypj
« Reply #17 on: Oct 30, 2013, 14:57:28 »
The Hall effect sensor boards I bought have power and pick up LED's, (went a bit OTT buying stuff  :o )
 I was thinking of drilling holes through trigger wheel to have 'flashing lights' when motor is running using the slotted 'points' cover I made
 ;D ::)
Any idea what the dwell is going to be using small magnet?
 I would expect it to be much higher than  the 45~50 % with points which will give a much better spark
« Last Edit: Oct 30, 2013, 15:00:10 by crazypj »
Brian Morgan, 1982
Offline Joon-yah
  • Joon-yah
« Reply #18 on: Oct 30, 2013, 15:23:39 »
I was just fucking with ya bout the harnesses,lol.
Cm400/cb450 http://www.dotheton.com/forum/index.php?topic=45376.0                                                  SR500 http://www.dotheton.com/forum/index.php?topic=43591.0                                                     http://retromoto1.com/
Online Sonreir
  • Moderator
  • Oregon
« Reply #19 on: Oct 30, 2013, 15:27:40 »
I know.  I was just trying to make you feel guilty for fucking with me.  :P
