www.Moto-Madness.com
Author Topic: Testers Needed - LED Headlight Bulb  (Read 6286 times)
Offline Sonreir
  • Moderator
  • Oregon
« on: Feb 09, 2015, 18:36:05 »
Hey all,
I'm hoping one or more of you guys could help me out.  I have some new LED headlight bulbs I'm hoping to sell, but I want to give them a test run.  Unfortunately, I don't have a bike at the moment that I care to dig into, so I respectfully request one of you guys do it.  ;D
The bulbs are 10W low beam and 15W high and use 4mm bullet connectors for the wiring.  The mechanical mount is an H4 format.
They are designed to work on 6V or 12V systems, so I'll need one of each, please.
Also, if you're going to volunteer, please be able to get these installed within a week and pictures of the night beam broadcast (both high and low beam) back to me ASAP.
As you're doing me a favor, you'll get to keep the bulb and I'll cover the shipping costs, too.
I only have two of these to test with, so it will be first come, first served.
Thanks in advance,
Matt
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline cosworth
Re: Testers Needed - LED Headlight Bulb
« Reply #1 on: Feb 09, 2015, 18:46:32 »
I'll put my hand up since I'm a former pro photographer and would get you some good shots.
Caveat is that I'm in Canada.
1981 SR250 café hot rod (sold)
1976 XS360 collector plates
1980 XS400 (on the bench)
1981 XS400 (in pieces)
2017 Husqvarna 701 enduro
Livin' the dream in western Canuckistan
Offline Sonreir
  • Moderator
  • Oregon
« Reply #2 on: Feb 09, 2015, 18:50:37 »
No problem.
12V or 6V?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #3 on: Feb 09, 2015, 19:19:33 »
OK.  12V tester secured.  I need 6V.
Are you 6V cosworth?
Offline Tune-A-Fish©
« Reply #4 on: Feb 09, 2015, 19:31:31 »
I don't have an application just yet that I can test, but am interested in 12V when they are ready for the market. What kelvin temp do you suppose? soft, white or blue light? is it a CREE diode? what input watts do you expect? I want to lower battery size and keep the starter so every LED I can run will be less draw. As a side bar, do you know the lowest amperage draw an electronic ignition (Dyna S) needs to fire, I would like to build a low voltage module to warn when the battery or charging system is at marginal output? also, do I need to add anything to correctly run all LED lights i.e. headlamp, brake and turn signals?
Thanks,
RD :o
Offline KICKRacing
« Reply #5 on: Feb 09, 2015, 19:32:13 »
I have a cl360 running a stock headlight, AGM battery, and one of your reg recs from about a year ago. I am willing to do this, will I need to cut the old bulb out type of thing?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #6 on: Feb 09, 2015, 19:35:43 »
Thanks,
RD :o
White light.  Around 6K just from looking at it?  Diode is CREE.  10W for low beam, 15W for high.
Electronic ignition draw is usually very minimal.  I would guess at around 20mA, but that is just a guess.
Turn signals usually requires special equipment, but headlight and tail light are plug-and-play.
Thanks, but we have a 12V tester already.  Just looking for 6V now.  But if you are interested in one of these when we're ready to bring it to market, you would need a headlight that is the non-sealed type.
Offline cosworth
« Reply #7 on: Feb 10, 2015, 04:05:07 »
12v
« Reply #8 on: Feb 10, 2015, 08:40:22 »
Thanks! we'll keep an eye out for the release.
Because I am in light ballast, LED driver manufacturing, I actually did some research last night for the lumen output and you should be around an .88 CRI with 7-850 Lumens per watt 6000K color might be close, but I'm gonna guess closer to 4500K, I think because of the perceived color of an LED it looks brighter... and that leads to my next question or comment.
The biggest problem I have with LED is that the light is very bright at 0-10 feet and lumen depreciation is rapid after. The key is the reflector and the lens have to work together to form a beam, much like adjusting a Maglight flashlight. It may be that along with the diode you might need a socket that has a lens at a preset distance from the diode like a TV projector lens? A test method may be a deep garage and a light meeter taking readings at 10' intervals until you match the lumen output of an incandescent or greater? I would be happy to loan you a quality meter. Very interested in the outcome!
RD :o
« Last Edit: Feb 10, 2015, 09:06:40 by Tune-A-Fish »
