I've been meaning to leave a review here with some pics but haven't gotten around to it so here is a short one.
This thing is awesome. I have it installed on my '72 CL450 in an aftermarket bucket from DCC. Sonreir is right that your bucket needs to have some depth to accommodate it.
It is very bright, has a white color to it and is very noticeable. I happened to have my bike running next to a friend's XS650 with a stock light and the light from my headlight completely washed his out.
It lights up reflective signs very well. The quality of the light on the road is a bit different on the asphalt and I haven't decided if it makes it any easier or harder to see details, but I think it is certainly an improvement over stock.
The high beam is crazy bright.
Since the LEDs are only on one side, it only illuminates half of the bucket so it looks a little different and the throw pattern is different, but again, I'm not sure if it is better or worse.
I will say I have had absolutely no charging issues since installing it.
The only problem I have had was "ballast" plug coming "unplugged" once but it was likely my fault during installation and easily fixed. I think I have had it about 6 months now
I believe this is well worth the money, especially if you have a weak charging system.
end of line
