Luugo86 said:Hey fellas I'm about to head back into the shop, hoping to get the engine apart short of splitting the cases and get it cleaned up. Going to start on the drum brakes today as well
I've read mixed things-is it possible to replace all the oil seals on this engine without splitting the cases?
Do you do this to make sure the case-bolt threads are clean and clear ? I may not be following youadventurco said:I use a bolt the same size(s) as the crankcase bolts (from old builds or spare bolts just make sure it's the same pitch) and cut a V in the threads on either side, file off the burrs and wind them in and out of each threaded hole... since I don't have a metric tap and die and some of em are deep on there. I use a tiny bit of antiseize when bolting em back up in case they gotta be split again (another ask me how I know)
