Awesome! Just FYI we switched to a Motobatt AGM battery because the speedcell was draining too fast at idle with the 40 watt headlight. Why do you think this was happening? I thought lithium held a charge longer?
OK... got the first sample prototypes in my hands. We have one wound with 18 gauge and the other wound in 16 gauge.
The test fit didn't go so well. I completely spaced the fact that the added copper and the three tabs on the side that are no longer used are trying to occupy the same space at the same time. Going with this setup might require milling (or otherwise removing) the now-unneeded tabs.
Matt need this system in a bad way yes will will need to mill the case tabs. What is the max charge the battery would receive and could we manage a LIPO batteries max charge?
