iatethepeach
Coast to Coast
trek97 said:still running the old stock flasher and bulbs I presume?
I haven't touched them, so that's my guess. I was going to try a new relay. Do you think it'd help, or are the old bulbs part of the problem?
trek97 said:Oh yea, and smear a little grease on the rubbers and side cover snapper things. It really helped w removal and install of mine.
I sprayed some WD40 on the grommets, but grease sounds better. I'll do it. The PO already cracked the left-side cover. That's something I need to fix ASAP or it's going to get worse. I intend to squeeze a little plastic epoxy into the crack along its length, let it set, then lay some fiberglass patch down on the back to make it solid.
