Thank you for feeling my painder_nanno said:Many years ago, I used a stick welder and stainless rods as it is easier to build up a weld in a straight line.
Garc said:Where do I go with the new rectifier and regulator? With nothing plugged in on that side, everything works(lights, ignition, starter) except the charging system. This has an igniter unit so I guess I own an SE special.
Sorry about the mess, any assistance appreciated as I am limited with time to troubleshoot. Trying to get this bike ready to sell, motor has a little port work singing through triple MAC long-tubes to single megaphone. I’m an engineer so logic is my thing, not electrical schematics. The last owner cut out a plug going to the white coil wires so I’m constantly blowing fuses trying to test and check where this eBay xs750 R/R connects, I confirmed the OEM unit was blown. Edit- I previously tested the new R/R while running, there was minimal A/C voltage between the white wires which is typically a stator failure.
Thanks,
Tim
Please do not hijack my thread open a new thread for your problem I'll be delighted to help there.Garc said:Wow, 20 pages since I last visited and all good stuff. Sorry, Can’t help on the video but sounds a little louder than standard valve-train mechanical noise. How’s oil pressure?
My 79 lost charging, traced it back to a coil with no continuity from the plug. Is this common? I assumed it was the R/R too, the previous owner did a little hack job on the left side with auxiliary lighting so hopefully I can clean it up soon. Can you test the stator itself, pulled the cover off and appears clean?
Sat all last summer from my wife deciding to get knocked up twice, fired up second kick but no charge to the new battery.
Edit, buttoned it all back together and now I have continuity between all 1-2-3-4 white wires. Might just light a spark and get insurance, don’t have time to think about a phantom short or redoing the harness.
And you had nothing to do with your wife getting knocked up not once but twice in a year i presume?Garc said:Wow, 20 pages since I last visited and all good stuff. Sorry, Can’t help on the video but sounds a little louder than standard valve-train mechanical noise. How’s oil pressure?
sick manGarc said:Apologies OP, I’ll start a thread if nobody PM’s me.
You’re right data, it takes two to tango but only one set of stairs to end a pregnancy...
Thank you irk.irk miller said:I have plugged tires. I know a lot of guys will say just replace the tire, that you will die, the world will explode, a volcano will suddenly appear in Vienna and burn the city down, but I have had no issues plugging a tire from a simple puncture like that. A tear is another story, but a puncture, no problem. If it's sidewall, I would also also say no go, but I have the impression we are not talking sidewall. In fact, when I brought my BMW home, the PO ran both tires with Slime, because it has Lester mags which are notorious for losing their seal around the beads from oxidation. Who knows how long he ran them that way, but I know it was for quite a while.
