looks like a sachs engine?
Check out treatland and 1977mopeds.com
If you get rid of the engine I will give you $15 for it.
Im building a motobecane moped chopper right now.
not to thread jack, but here is a picture:
it is mcdonalds themed
....Epic.... where is your build thread? Also treatland is where i got the puller i needed to find out i'm a moron and didnt have spark because the vice grips were grounding out on the frame
The mongoose tube is aluminum.....the plan is to get it to bolt onto the frame for added rigidity and a place for the tank to sit...I just got acetylene tanks and torch setup the other day just need to fill them and i can start welding the tank....since it will be my first tank i went with an "easy" one as my inspiration long and flat like this one here
Got them at the used motoshop a town over...they normally dont have new stuff but they bought out an old dealer so they had these clubmans ......they're too small for a motorcycle but perfect for this
no build thread for the moped, its too sporadic haha.
you could easily find a steel tube to weld in there. maybe cut a junk trampoline? idk.
seriously though, lemme know if you get rid of that engine!
cheers
