Sachs 650 Street tracker/ Now with video !!!!!!
Re: Sachs 650 Street tracker
Now its back on the ramp and the front end is off New fork seals/oil and spray up forks / tripel trees,
Thats my nephews boys bike not my next project!!!!
Will post more when more happends
Mate that's gonna look great! Love that exhaust and those 'bars are gonna give you the right stance as well. I love a good reverse megaphone...
Personally I think your dual seat will be all you need... seems to be the shape you're looking for without needing to worry about the single seat.
Cleaned up the oil cooler and gave it a fresh paint
Front wheel cleaned up real well
Im gonna make a front fork brace out of 6mm aluminiam flat bar
One problem im having is getting the exhaurst bolts out !!! useing penatrating oil and have ordered some bolt exstractors
Re: Sachs 650 Street tracker/ Carb upgrade
This bike uses the same carbes as the CCM R30/644 DS so there,s loads of info out there on upgrading these
what iv done is put 150 main jet and a 25 pilot
then i ditched the TPVLC and blanked the holes/suzuki part No 13274-84000 cap/09401-06101 clips
then set the TPS (throttle position sensor. The way i did it was remove the plug on the sensor connect a multimeter across the two end pins on the carb sensor and take a reading (older meters set to 10K Ohms and digi one set to 20K Ohms) mine read 6 Ohms with the throttel shut now i cable tied the throttel open i then take my 6 Ohms x 76% - 4.56 this is the reading i now nead when i put the multimeter across the outer and middel pins buy undoing the two screws just a tad i can then move the TPS untill i get 4.56 the recheck after tightening the screws
I found all this out at WWW. CCMrider.co.uk thanks for that guys
Things are coming a lone abit now
Thought i would keep them red, Why not!!!!
Wrapped the exhaurst and put a few bits back on just to see what it looks like
And i started it up for the first time!!! fired up stright away sounds real loud but sweet!!!!
jobs to do now are
single seat (flat track style)
fit rear light/ winkers
dump the air box for K@N filter
front fork brace
front fender
then get it painted (not sure of colour or decals yet)
And ride the thing (that all sounds to easy)
Thanks pete, im really enjoying this build, got my caferacer in the copdock bike show next week so not mush going on on the tracker this week
nice touch with handwriting on the tank! gives it that TLC thingy.
Cheers Bert, just trying out an idea for some decals :eek:
Had a good time at the show well hot 29c !!!! in october! 8)
will post pic when iv up loaded them.
Not much going on this week either just seem to be busy at the mo? :p
