SL350 Dirt Scrambler
+1 it aint that hard to do
and be sure and get the right gasket it is specific to the kickstart only SL, CB/CL clutch cover gaskets will not work
i wouldnt use a disc to clean the gasket surface ,too messy,too much asbestos dust,box cutter or razor blade works for me
This is great news i had thought you had to crack the case too. Will this work on a CL450 as well? I have one that needs replacing.
Since the shaft doesn't engage anything internally on any of these Hondas, it slides right out... assuming they aren't bent. Hah.
Special socket? It's just a circlip on both bikes.
you gotta pull the oil filter rotor to pull the clutch takest that speacial socket
the shift shaft arm on the 350/450 goes way up in behind the clutch i am not sure you can pull it without taking the clutch off
Oh right. I forgot that the driven gear won't clear the oil slinger.
Spend $12 and get the socket. You'll want it to do a proper job. If you don't already have an impact driver, stop now and get one. It will save you a LOT of grief.
yeah git the special socket worth ever penny ;)
images
http://data:image/jpeg;base64,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
Great news guys. I have all the tools and the special sockets. It's just good to know i can do it without taking the motor out and racking the case.
Great resources you guys are.
thanx
xb33bsa said:
if the spokes are not rusty you should be ok
4.10 is huge for the front it will slow down handling,the extra weight is not gonna help the suspension and may not even fit in between the forks
1.85 rim is plenty on the front and a 90/100 tire is as big as you want to go that is what i am using on my sl
Yeah I measured the fork, fenders, and clearances, its exactly 4" if you want to have the front fender. If not I can probably squeeze in the 4.10 tire. But I think I am going to go with the K70 19x3.50 tire for the front.
Redliner said:
To replace the shaft, you only need to remove the clutch side cover, loosen the oil pump and move the clutch assembly with oil pump out a bit to make clearance.
The clutch has the pump piston attached, so the clutch and pump must move together.
No need to split the case. Took me about a hour and a half at a leisurely pace. That was with new gaskets. Your gasket material will tear and will stick harder than glue. Need to use some M3 roloc discs. The grey ones used to strip paint will polish the surfaces very gently. Just clean up so no crap gets left inside. Perfect opportunity to clean bottom of the case of all of the sludge and to clear the oil pump screen.
Don't put knobs on it if you are going to be on the highway often. It sounds like a long loud muffled fart and will make rides unpleasant with the buzz throughout the frame, seat and bars.
Oh nice, thanks for the tip, I haven't gotten to the motor yet, been busy. But great tip! Thanks
Yeah I have dunlop k70 tires on my other bike and I can hear it buzzing sometimes, no vibration though.
images
sweeet!
So I've been busy and haven't paid much attention to the bike lately. Except the triumph tank has had me scratching my head about how to mount it and such. Plus the petcock is kinda towards the center so into the engine.
So I've been playing with ideas about other tanks and found this old yamaha gt80 tank. Its nice and small and super clean inside. Might be a much better fit and mount.
Any thoughts on which to go with?
they both look awesome !!
personally I would use the alloy one and raise the seat up just a bit in the front and have a border trim under the seat edge to blend with the frame 8)
