So lost...CB360
Sonreir said:
You'll want brown and not brown/white for your parking circuit. And I don't recommend using the turn signal for the parking light, since the ignition switch will have power running through the brown wire when the switch is in the ON position.
I get this when I test the switch/ look at the factory wiring diagram.
OFF:no connection
ON: black to red & brown to white/brown **
PARK: red to white/brown
**It looks like this breaks a connection between the tail light and the rest of the incandescents on the bike so that when in park the entire bike doesn't light up. Without needing to isolate the left blinker circuit (the handlebar switch does this for me) I'm just leaving the brown wire detached. When the bike is on, there is no power running to the left signals.
I'm more asking than stating a strongly held belief...
Sonreir said:
Also, the stator isn't three phase, it's single phase, so you should have a separate yellow, pink, and white wire and not three yellows.
I hear you are working on something in that area =). Im following and interested in the outcome.
The rectifier manufacturer specifies that the pink/white/yellow can be attached to any yellow wire. I should probably fix the graphic to specify the wire color to the alternator. This is an area where I know that I don't know anything at all. Whatever is happening inside that gold unit is magic to me.
Install diagram is here
Sonreir said:
What's the purpose of the DPST switches? Is the dimming not being toggled with the KZ control?
When I wire up the pass switch in a way that makes sense to me I have a switch that is blips the high beam as long as the headlight is switched on. (I've never had it wired into a factory location, so I'm not sure what normal functionality is)
The first DPST relay changes the functionality sot that pressing the switch blips the low beam if the headlight is off and the high beam if the head light is on. If the highbeam is on, nothing happens.
The second DPST relay cuts the high beam if the high beam is on and doesn't impact the circuit if the hi beam is off.
I still haven't figured out the zener diode circuit for the idiot charge light. I've seen the $16 green/yellow/red LEDs on ebay, but I don't know how much effort it will take to hack it into the appropriate housing to fit in with the other indicators.
Weird... normal ignition switch wiring for the old Hondas has everything you describe, but park output is brown and not brown/white. If yours tests out differently, keep what you have.
The rest sounds OK to me.
Thanks for the gut check.
I'll double check my continuity. I've got a cheap emgo reproduction main switch(though it feels solid enough) so it's possible a wire was hooked up backwards (and equally possible that I wrote my wiring notes down incorrectly.)
Ok.
Stumped again...
I'm back in town and worked through all of my known issues:
  • Pulled the carb slides and cleaned them up with emery cloth. They had some burrs for sure and one was stuck enough when I pulled it that it probably contributed to the bike dying.
  • Cleaned the slides off with WD40, thought better and finished them off with simple green.
  • New OEM battery ground
  • New AGM OEM spec battery
  • Checked over all the wiring and wired in an OEM fuse box (used to be one I made from scratch)
  • Added an inline auto-reset circuit breaker between rectifier and battery
  • improved the ground from the rectifier to the battery
So, wiring all looks good. No shorts to the coil power when the other functions are used. Strong power to the coils when the kill switch is closed. All controls function as intended.
Charlie's Place sent a replacement ignition unit (just the pickups) and it functions the same way as the last one. Test light never dims when ignition spins. Spark plug doesn't fire when kicked over. They tested the unit as functional before sending it to me.
Coils tested out as good, which doesn't make any sense to me. The only thing I can think of is that maybe I lost my magnent(s) in my advancer mechanism? Anything else we can look at? Power is going to all the right places...
Other things I did while I was in there was to drain the tank, install a Kehin petcock to replace the broken tube on the knockoff, new OEM fuel line to the carburetors.
None of these things above impact spark, so I didn't put them up top.
If your magnet was missing, the light wouldn't be coming on at all. The magnet serves the same functions as the points closing- which is to send the current from the ignition to the coil's primary windings for the coil to fire off. It's possible you're wired wrong or your leads are in the wrong place.
eff yes. Thank you. I'll poke around in there for a while. I'd rather be wrong and have something to try than be right and out of feasible options.
So, I'm going to say that I don't see how it could be the wiring. The bike ran with these coils as wired until it didn't. If the coil leads were swapped from the factory, it would have been true then when it was running as much as it's true now that it's not. As to the rest of the system (electronic ignition), it's four wires. Two black to ignition hot, a yellow, and a blue. Worst thing I could feasibly do is swap blue and yellow which would give me bad timing( as opposed to no timing...). I checked that the magnet cylinder and advancer were actually spinning with the stator/timing thing. They are. Looks to be magnets in there as well.
Here's what my two coils are doing. Maybe I fried them?
I tested between 3 locations:
A:Hot into coil from kill switch
B: Timing to points/electronic ignition
C: Plug Cap.
LEFT:
A to B was 5k resistance.
B to C was 16.4K resistance
A to C was 16.4K resistance
RIGHT:
B to C was 16.8K resistance
A to C was 16.8K resistance
This all makes sense to me because I've got 5ohm plug caps... Am I missing something here?
Those numbers don't look right to me, but I might be a bit confused for what you mean by B and C.
Resistance from the black/white wire on the coil to the end of the spark plug wire (including cap) should be 5K. Resistance from the black/white wire to the color wire (blue or yellow) on the same coil should be five Ohms.
Secondary resistance should be closer to 10k ohms. Usually reads just over 9k.
oh, shit. I see. I added a K to the value between the two coil leads.
5 ohm between the colored (blue or yellow) and black/white.
12.4K ohm between the plug wire and the black/white.
12.4K ohm between the plug wire and the colored.
I'm not worried about a 400ohm or a 1-3% out of tolerance between the coils. Should I be? The dyna coils have 17k ohm resistance specified for the same application. Unfortunately, I can't find factory specs for the 360 at all.
I've got a fresh set of factory points on the way (i stripped out the old mounting plate and thought it would be worth having a new one with a fresh pair of points on hand for troubleshooting.)
Resistance in a coil rises with heat. Was it hot when you tested it? If it was room temp or thereabouts, then you may have an issue with your coils. They may read as much as 16k ohms when hot.
OK: so those coil values are ok. I got new points in, installed them, timed the bike and it fired right up. Just for good measure I put the Charlie's place ignition back on and got nothing. Switched the leads (because sometimes when you only have two options you still get it wrong) and still nothing. I'm pretty sure the magnets fell out somehow. I doesn't pull in the smallest steel wire as I bring them close. I like being right about the coils, but I'm bummed that I've spent the past month chasing down the wrong problem and had to convince the shop who manufactures and sells these things that it wasn't user error. I just sent them another email with a video of the bike running with the points on.
End of the story is that the bike runs and it will probably keep running for a while. I need to get new points hardware (screws) as the ones in there are a little buggered, but that could wait until the timing goes out of whack next.
Side notes: I didn't realize that new old stock points could be surface corroded out of the bag and not work properly. I used a fingernail emery board and some de-oxit gold to clean them up (which didn't seem to work) and then dragged a piece of clean printer paper through each side and they worked perfectly.
Secondly, I had to make another revision to the wiring diagram. The main fuse blows if I engage the left blinker switch while in park. For now I've just disconnected the blinkers (who needs them.) I'm pretty sure the short was backwards through the two pin blinker relay. I can isolate that switch using the 4 pin switch (as designed by honda) or hook it up to the brake light like it was from the factory (attached wiring diagram) I'm mostly posting this stuff here with the hopes that someone else finds it and it helps them figure something out.
