pkoster
Proud member of the blue CB360 club
Redliner said:That is your rectifier. Your regulator will look like a very small snuff tin or rounded box.
Here is a shot from the other side. The regulator is not wired in, was never wired as I recently found out. So I'm hoping the rectifier also regulates....
I've also attached a pic of the battery from the top. To me looks like it's been leaking, but I'm, not sure if that has always been like that or is a result of no regulator. Also thought I would disconnect the battery +'ve while running and check the voltage on the cable (not the battery) but I don't want to damage the rest of the circuit if there is no regulator and too much voltage is allowed without the battery pulling it down.
Cheers
