Tire Size Question
slategrey66
Active Member
I have a 1995 CB750 Nighthawk, I'm swapping to a YZF-R6 Front End with Factory rear nighthawk wheel and factory R6 front wheel for my scrambler project. I want to use the Kenda Big Block Tires
They do not have the exact size that's a factory size, which size is recommend i should go with?
REAR TIRE
Factory:
Tire - Rear: 140/70-17
FRONT TIRE
Factory:
120/70-ZR17 58W (This is what I pulled from Internet)
http://www.kenda.com.au/products/category/QVJWKVNJ
This is the look i'm going for, Thanks in advance for your help.
First make sure they are DOT certified if you need that kind of certification in CA. If the bike is already certified in you name, you will still need to make sure the tires fit your rims.
