danker16
crazypj said:Sorry, your trying to relate apples to alligators
3 jet Kei-Hin carbs have fuel flow through primary main jet to pilot/slow jet so total fuel doesn't increase with increase in pilot jet size
On Mikuni it does but this is Honda CB/CM which are usually 3 jet (450 may be 2 jet)
Needle isn't 'fine tuning' it will control low/mid range, most are not adjustable (except in the 'wrong' direction by shimming)
Old bikesdon't 'go lean' they always were lean, from 1976~77 onwards
The fuel formulation changed, anything with alcohol in is leaner than 'pure' gasoline, it's normal to have to up-jet by 7%~10% even on a stock motor/airbox/exhaust (alcohol test kits were available in 1970's to find out percentage when bikes had running/overheating/seizure issues)
so what else does the primary main do beside limit fuel flow through the pilot jet, does it supply more fuel to the engine through another circuit? the manual from my Kawasaki only explains the slow jet and secondary mains, or maybe i just dont get it
