New sprocket cover is on, trying to dial in the clutch to where I had it before. Walking the line between too tight and too loose, seems like I can either get it so it it doesn't drag the motor with the clutch in but it slips, or it drags the motor but doesn't slip. Also, chasing a bastard of an oil leak... Front right oil feed is leaky. Looks like the o-ring pinched on the outside of the head on re-install so it's leaking from the top of the tube. Tried putting some gasket goo on it, but didn't seem to help. I figure the oil is weeping enough that no matter how well I get it cleaned off, it will still interfere with the bond. It's to the point where if I run it then park it for a few hours, it'll leave a small spot on the ground. Debating just trying to use the goo again and just putting the lower fairing on to catch it until I pull the head again... I really don't want to pull the head just to fix a small oil leak, especially without having a garage or shop.
