SpottheDogg
Here is my rear brake set up.
crazypj said:I like your rear brake set up much better than the flip arm/bent rod solution.
It should work far better.
I'm going to make a piece to do same on the quick build I'm doing now (needs to be ready by next Saturday for Mods and Rockers 8) )
dp9 said:low-pro grips? im confused, thinner handle bar grips made riding the bike better?
SpottheDogg said:Thanks, I wasn't completely sold on the bent rod idea either. I just scrounged for a disposable 12mm box wrench, the type you get with furniture etc. and welded it to the stock bolt. Try to find a thick one if possible. You could also retain the stock rear brake light with my set-up but I cut/ground the tab off long before I did this. I still use the spacer but cut off the little hook/arm that actuated the switch.
DOB said:Where did you get that battery box?
CBdublin said:Nice! rode my bike for about 15 miles today at 65... think my ass bone is still vibrating. Congratulations!
