Kamn said:and before the hair dryer you can push in a micro fibre towel to soak up the water, remove towel and blow dry it
Thanks man. Will do.
Any ideas about the petcock and cap hole during sealing?
thefish said:Thanks man. Will do.
Tune-A-Fish© said:Yeah... don't use sealer... fixit. ;D
Tune-A-Fish© said:How much is the sealer, maybe weigh the cost.
540Nova said:Critical that you run wire periodically in the crossover tubes, you don't want those plugged up!
After dumping excess, run wire in those, and prop at an angle so sealant doesn't drain into them
Tune-A-Fish© said:No cross tube mang. just take your time and do it right.
advCo said:This is what your tank would look like if it had a cross tube, just flip it over and look at the bottom.
