chris7981
Active Member
Back story (questions in next paragraph if you want to skip this part): so I bought this cb360 last winter for seven hundred bucks. I got it running (poorly) when I got it home and decided the carbs sucked and moved on to the next project... like you do when you have like 6 bikes and ADD. fast forward to late summer, I randomly order some mikuni vm's from speedmotoco for it. I put them in and tune them for like three days and finally got them tuned!! So I took the old girl out and she ran like a champion!... for like 2 laps around the track till she came to an abrupt stop. I most not have tightened that last valve adjuster down tight enough because it decided it would rather live in another part of my engine, like, the bottom. It got into a fight with the cam chain on the way down and kicked his ass (to pieces). So I pulled the engine out of the bike and did something I've never done. I took it completely apart, split the case and everything. turns out, it was a good idea because not only was the adjuster in the bottom but so were lots of pieces of the cam chain. I'm in the process of cleaning now. since it's pretty much just a bunch of aluminium blocks now, I want to give it a fancy shine before reassembly.
So now that this motor is completely apart, are there any upgrades or fancy things I can do to this thing before putting it back together? you know, stuff to make it go faster, be cooler and get me more chicks? I read about the cam chain tensioner so I'm gonna do that, should I bore up to something? I've read about the gs850 piston swap and it's limited availability. I've also read there were some other problems with this engine but no particulars. and I think I read somewhere that someone was doing 70 in second gear on one of these things.. I could get into that. Anyway, any words of advice, helpful hints or tricks, sage like wisdom, asshole type comments about how I'm dumb for buying a cb360 or whatever are all welcome.
