GR650......starting over for the last time
Big R
Heaven is so far away.
I feel like I can't just keep adding to the last thread so I'm starting over here. I won't be going into the history of everything I've done (maybe a link or two when it's pertinent) so this will be like starting from scratch on a bike that I know very well. But here is a link to the last thread for those that are interested :
http://www.dotheton.com/forum/index.php?topic=18045.0
Here is what I'm starting with :
Basically, just a frame, engine, and carbs. Stay tuned folks.....plenty of changes coming up.
IGNORE ALL OF THIS BELOW! It's for my reference only (and nobody ever re-reads the first post anyway......
Front end:
Bandit 1200 / RF900.,.,.,.,.,.,.,.,.,.,.,
Rotors (4mm minimum, GS500 right, RF9 or B12 left):
Calipers
Gsxr MC: $80?
GSXR left control (hazard button)
GS500 right control (light relay)
EBay speedo: $75 ish?....................
GSXR induction ports $115
Number plate $21
Airbox tubing (1.75") $15/ foot
Rear end:
Ask about upgrades first!
Rear pegs = 8.25" behind pivot
Katana rear wheel (17"x4.5") $53
98-06, 17mm axle
150/70zr17 tire (25.2")
Katana rotor
GS500 caliper
Kat caliper mount?
16 tooth sprocket (520 chain)?
16T suzuki part # 27511-37200
16T JT part # JTF434.16
GS500 rear sprocket (520 chain)
New chain $110?
Caliper rebuild kit?
Axle w/ spacers
Brake hanger & stay $18 & $17
09263-25024 = $14.51 (*2)
08211-16381 = $1.27 (*4)
61262-49201 = $6.60 (*4)
62657-31301 = $11.04 (*1)
Miscellaneous:
New stator? $130 ish
GS500 coils?
Need seat covered
Rear led "angel eyes"? $41
Base gasket $23.30
Head gasket $32.50
Right side gasket $10.32
Left side gasket $8.06
Tank pads: $53 on DK (7.5*14.75?)
Need 2
https://www.denniskirk.com/stompgrip/universal-clear-traction-pad-sheet-44-10001.p5201715.prd/5201715.sku
UFO rear fender: $19
Front height:
Stock forks 31", 100/90-19 tire = 26.4". Total 44.2
Stock forks 31.25", 110/80-17 tire = 24.2". Total 43.35"
Bandit 1200 forks 30.5", 120/70-17 AM26 = 23.9". Total 42.4"
Difference between all stock (44.2) and extreme (42.4) = 1.8"
Stock rake: 27.5°
Stock trail: 4.4"
1" od frame tubing, .875" id, 8'
.870" od, .120" wall, 4'
$71 shipped
Mileage :
With VM34's
Averaged 28.41 mpg
With BS36's
Averaged 36.28 mpg
Installed VM34's, R/R, coil relay
Averaged 39.37
Advanced timing and other igniter
Averaged 33.15 mpg
Retarded timing back to stock
Averaged 39.56
SIgn me up, since I have no project bikes, I need to live vicariously through those that do.
Subscribed. Loved the previous embodiments of the GR, Rich. Can't Wait to see what comes next
I am contractually obligated to subscribe to any GR thread! Can't wait to see what's in store! ;D
You can bet your bollocks to a barn dance, John. I'll be getting to that eventually ......
Once I get some time in the garage, I'll be taking pictures of updates.
Some links to the other thread of stuff that is staying......
Ducati shock info and GS750 aluminum swingarm:
http://www.dotheton.com/forum/index.php?topic=18045.930
Gas tank stuff (goes on for a couple pages.....)
http://www.dotheton.com/forum/index.php?topic=18045.810
There's some details with the carbs in all there too, but I'll be touching up on them eventually anyway.
Stock foot peg mounts:
Don't need all that steel in there, do I? Still needs some cleaning up, but I'll get to it.
Complete triple tree from a 94 RF900, 43mm forks from a 2001 Bandit 1200, and clipons from eBay:
Fairing mount from an 86-87 GSXR :
Mounts welded to the neck via Bradj (thanks buddy!). The crappy welds for the steering stop are mine however.....
Fairing bracket mounted up. Notice the upper arm for the speedo is bent - because it was rubbing the hell out of the windscreen:
From the side:
Oddly enough, that's all the pictures I have available right now.
Interested in how you're tackling the fairing mount since I need to do the same thing on my CB, looks good.
Good to have you guys along.
Upper fairing mount welded to the back bone (I'll make a Y shape support that will connect this to the mirror mounts):
