Tune-A-Fish said:Haah! 30 seconds and BAM! $5.50 BIN: http://www.ebay.com/itm/3191-Honda-XL175-XL-175-Rear-Brake-Pivot-Shaft-/130940806520?hash=item1e7cae2578&vxp=mtr
xb33bsa said:you are going to go thru all this work and find it is the slowest LEMON of a 175cc motorcycle ever made EVER :'( :'( so many other bikes out there that are a better choice to put sweat and tears into
deviant said:I can't see that brake shaft working for the kick starter. The radius is right, but the splines don't seem to line up. Plus, there is less than half the length from the
groove for the set screw to the end of the shaft. Your kick starter lever will barely be hanging on.
I did. That's what Im'a saying.Tune-A-Fish said:Was worth checking out... never know what works till you try /
deviant said:Plus, I don't think the issue with breakage on these is the design of the shaft. It's the design of the lever. It's already hanging way out there. The way they tighten, the fulcrum is already out to the end of the shaft. Using the brake shaft will put the fulcrum beyond the tip of the shaft several mil.
