MCR, do you have any other pics to share? I'd like to see how it looks from the front. Very impressive build though. I like it. ;)
Fill your boots Stogz.........
I've put a video in the Show & Shine section, showing the screen removed...turn up the volume.
fordop87 said:
I dig your 450 lstuckey1. I'm working on one as my fist build.
Questions...
Did you drill your own brake rotor?
And what is that exhaust muffler and how do you like it?
Private Message Sent.
Before and now, still working on it.
Here's a few pics of "Sandie". (My 4 y/o daughter helped me name her.)
I picked her up in June 2011 as a gift from my in-laws. They purchased it off a craigslist ad I saw. It did not have a title, there were lots of major dents, broken parts, and rust! Lots of work. Yes, and I was able to obtain a title.
Beginning:
During the tear down:
The right cylinder was stuck due to rust, despite soaking in PB Blaster for well over a week. I used a 3-lbs sledge hammer and a 1" diameter steel pipe to pound it out. I had the cylinders bored over .50.
The reason I used a steel pipe was that the steel punch didn't work...as you can see!
Some of the scoring in the right cylinder prior to it being bored.
Primed frame
Freshly painted engine:
New pistons
New cam chain tensioner sprocket and roller
Starting to come back together:
One of my little helpers wearing his PPE (Personal Protective Equipment)
Getting closer to done
New mufflers
Freshly repainted/rebuilt controls
New Battery....Old Battery
Mounting system for the new battery
And from the bottom of the battery mounting "bracket"
Tank damage repaired
More tank damaged repaired
Almost done
Paint and bodywork done
New seat cover
And finally, the photos from today. I have the K&N filter pods off while I continue to tune in the carbs. I also plan to eventually add some turn lights and maybe change the mirror setup.
Amazing build wrath. Where did you buy those front turn signals? I'm assuming those are turn signals anyway.
