Before and not quite after.
All but the badges and fine tuning.
she's changed forms a few times now... 1970 Honda CL450
canyoncarver said:
Nice bike. Do you have more pics and info on the intake setup you did?
As soon as she is badged up ill take a heap if pics and post them up.
Intake is pretty stock. Stock carbs with new jets. I used a uni filter on the intake as the old box filters had perished. I still have a bit of tuning to do as she could run a little richer.
Check out the build thread bellow if you want a few more pics too I think there's one of the intake on there.
Heres me new build..
Before
After
Specs:
Rebuild motor, 1st overbore, new rings, gaskets, seals, valve seals, etc etc
PMA Swap with RD Rotor, and GSXR reg/rec
Pamco High output ignition with green monster coil
Triumph Capacitor
Minimal wiring all wrapped in braided sleeving, to a new mini fuse block under the seat
RD400 front end with air valves
Super wide #10 bend bars
4.5" Light
Mini throttle housing
KTM dirtbike brake master
Bronze bushings
12.5" gas charged rear shocks
Drilled and Rebuilt drum
Skate wheel tail light
SHorty fender
Handmade seat
Every nut and bolt was replaced with new, all the aluminum polished, etc etc.
Bangin!
Before
After
Specs:
Triumph Capacitor
4.5" Light
Bronze bushings
SHorty fender
Handmade seat
Bangin!
Hey tron! Do you have a picture of that "Skate wheel tail light"
It sounds sweeeeeet!
79 KZ1000ST Before and After
my '78 GS550E
My Yamaha SR250 - just finished
