www.Moto-Madness.com
Author Topic: The SkyTeam 'Ace' Resource  (Read 486352 times)
Offline stroker crazy
  • crazy as a fox
Re: The SkyTeam 'Ace' Resource -fuel line
« Reply #2500 on: Nov 30, 2016, 07:27:29 »
Adding a little bit of red to the Silver Bullet
Undoubtedly this is only the start!
Crazy
“Ride like the Wind” W.H.
Offline Sneikz
« Reply #2501 on: Nov 30, 2016, 18:54:54 »
Crazy
Correct. Pick up the new red seat today.
Sent from my SM-G920I using Tapatalk
The Silver Bullet Thread: http://www.dotheton.com/forum/index.php?topic=71205.0
Silver Bullet Pics: https://goo.gl/photos/EXyfM3K42BHp2D6w9
Aces on the net: https://goo.gl/c8QmjP
Silver Bullet mods booklet: https://goo.gl/97mGRI
Other Bikes:
2007 Suzuki Boulevard M50
2005 Tomos Revival (TS)
Live long and ride hard \\ //
  • crazy as a fox
« Reply #2502 on: Dec 03, 2016, 19:38:23 »
Indicators continued:
Installed M10 x 1.25 thread inserts, removed internal ribs, started polishing.
Drilled wiring access holes in mounting bolts.
Awaiting BA15 sockets from the Middle Kingdom.
Offline kevmaster
« Reply #2503 on: Dec 04, 2016, 08:58:54 »
A red seat...on the silver bullet...you must post pics...
Kev, bavarian Acethusiast
Offline Sneikz
« Reply #2504 on: Dec 06, 2016, 03:38:55 »
Indicators are looking good!
Watching with hand on wallet!
Other Bikes:
Offline Sneikz
« Reply #2505 on: Dec 06, 2016, 03:40:51 »
Unfortunately a high class lounge chair took precedence over "The Silver Bullet".
Will post as soon I recieve.
Other Bikes:
  • crazy as a fox
« Reply #2506 on: Dec 06, 2016, 03:48:22 »
a high class lounge chair took precedence …
Some people have no sense of priorities!
Crazy
Offline kevmaster
« Reply #2507 on: Dec 06, 2016, 04:57:59 »
When you put the chair in the Garage, just to watch your bullet, then I understand it...sit in front of your Baby....I would do so... ;)
Offline kevmaster
« Reply #2508 on: Dec 08, 2016, 09:29:59 »
Hi Acethusiasts,
just a short question. Does someone mounted a revcounter on the ACE? And how do I connect it, that it Shows the rpm? THX for help.
Rgds
Kev
Offline 2b
« Reply #2509 on: Dec 08, 2016, 15:02:08 »
I run the black version of this.
https://www.louis.eu/artikel/t-t-multifunction-instrument/10034806
Tachos usually come with a wiring diagram. The pick up for the revs sometimes comes from wrapping a wire a certain number of turns around the lead between coil and spark plug. It reads the pulses that are being sent to the spark plug. There is also often an option to tap in to the wire between the CDI and coil. See Type A and B in this diagram.  Depending on the model, there will probably be a setting in the tacho to tell it whether the bike is a 2 or 4 stroke. Here is the wiring diagram for my tacho/speedo
https://cdn2.louis.de/content/catalogue/articles/zusatz/anl/T&T_english.pdf?_ga=1.61538988.1447467012.1481222961
I had trouble getting mine to sense rpms properly using either method, jumped all over the place. But eventually sorted it. See my most on March 22nd and before in here
http://www.dotheton.com/forum/index.php?topic=61167.30
« Last Edit: Dec 08, 2016, 15:09:16 by 2b »
He's obsessed with order and clarity. He doesn't like mess.
Harold Pinter
Build thread: http://www.dotheton.com/forum/index.php?topic=61167.msg694438#msg694438
