www.townmoto.com
www.Moto-Madness.com
OUR ADS ARE FROM SUPPORTERS OF THE COMMUNITY - CONSIDER TURNING YOUR AD-BLOCKER OFF FOR WWW.DOTHETON.COM :)
Author Topic: Yamaha SR250 - A clean standard build  (Read 121787 times)
Offline zap2504
Re: Yamaha SR250 - A clean standard build
« Reply #740 on: Mar 18, 2017, 15:49:50 »
That does look good with the new seat, stance, and tank reposition. Do the covers strap onto the frame tubes? Back-side pics?
Offline JadusMotorcycleParts
    • Jadus Motorcycle Parts
« Reply #741 on: Mar 19, 2017, 05:29:37 »
Thanks guys.  Yeah I took some photos of that, forgot to share - see below.  The rear of the covers is far less attractive than the front.  I used filler to make somewhat of a mould and pressed it onto the magnets I had on the frame while it was still soft.  I covered the magnets and brackets in grease so the filler wouldn't stick.  Then I cleaned up the filler (dremelled it back to a smooth clump) and glued and screwed the neodymium magnets in place.  On the frame are just standard 7/8" and 1" tube/pipe brackets (that I will eventually paint black) with a large countersunk screw head - these are what the magnets pull on to.  They seem to hold in place really well, but we'll see if they stay there when riding.  If not, i'll try fixing them from the rear in another way.
« Reply #742 on: Mar 19, 2017, 15:44:31 »
Here's how the backside ended up after sanding and painting.
Offline zap2504
« Reply #743 on: Mar 19, 2017, 16:01:55 »
Ok - so the silver straps on the frame tubes (above pics) hold the neodymium magnets in place.
« Reply #744 on: Mar 20, 2017, 18:34:56 »
Yeah almost.  The magnets are actually inset in the filler on the inside of the covers - held in place with a screw and glue (they were magnets with a countersink on one side).  Then the frame just has some bolt heads.  If I need a stronger clamp later, I could add magnets to those braces as well - bolted on.
« Reply #745 on: Mar 25, 2017, 16:07:34 »
Got a nice ride in today on the test mule.  Spring is definitely in the air, although air temps have not made it to 10 yet!
« Reply #746 on: Mar 27, 2017, 14:03:50 »
Things have been getting a little OCD here at the end - decided I didn't like the ugly goldish plated screws of the new non-vacuum petcock I decided to go with.  So I trimmed up some stainless ones.  Much better  :D
Offline Oz350Four
« Reply #747 on: Mar 28, 2017, 01:55:50 »
OCD is good...
"Me speed officer... never..!!"
1972 Honda CB350 Four - Project Ol' Red
2007 Harley Davidson Softail Deuce - sold to start this project
Offline Brodie
  • Gold Coast, Queensland
« Reply #748 on: Mar 28, 2017, 03:58:38 »
Looks better. Not full OCD, there is still a cast mark on the petcock switch.
« Reply #749 on: Mar 28, 2017, 18:15:49 »
Haha, I agree, that mark on the petcock plate really bothers me!  Gotta draw the line somewhere I guess.
No all mounted - along with the harmonic intake and foam filter - with Jadus logo  :o ;D
