www.Moto-Madness.com
Author Topic: CBX550-Brat/urban scrambler on a budget  (Read 40134 times)
Offline NoRiders
Re: CBX550-Brat/urban scrambler on a budget
« Reply #180 on: Sep 12, 2016, 19:11:47 »
Battery issues all pointed at two duff chargers....so bought a new battery maintenance charger so trickle charge duties in the long term. Short term, it gave me a fully charged battery which span it over a treat.
No go initially, but a generous squirt of 'Start ya Bastard' soon had it firing/running.
Dah gud shit
I don't have the tank on yet, so just the full carbs but it ran on the throttle for 15secs or so, long enough to know it's OK.
Exhaust is now on as well.....
My attempt at disguising the middle down pipes to make it look like a twin (from 30yds) failed haha!
Quite liking the silencer, it terminates at the hub spindle which is short enough (for now) at least.
Offline Maritime
« Reply #181 on: Sep 13, 2016, 10:50:38 »
Lookin good!
Offline NoRiders
« Reply #182 on: Sep 16, 2016, 14:57:41 »
Lookin good!
Thanx Marytime  :)
Did I mention it runs...yay.
However, due to me being a clutz, I left the ignition on and drained the battery...the maintenance charger I recently bought will charge it up but paainfullly sloooowly...so I treated myself to a gruntier version:
If that don't shoot some juice into the MotoBatt nothing will.
In other news, I attempted to swap the petcocks over from the CBX tank to the 400/4 tank....easy right? Wrong! Buggery bugger....thought the petcock swap would be a synch...pah, thread on the 400/4 tank is coarse whereas the CBX thread is fine...so much for just swapping them over
Just ordered an aftermarket 400/4 petcock from Mr David Silver......let's see if that'll work?
I've heard of sketchy quality and leaks from cheaper cocks but if DS sells 'em they should be OK.
I was concerned about using the 400/4 petcock as the fuel outlet bore is narrower than the CBX bore, but the petcock, as listed, will suit up to 750/4 models so the flow rate should be OK to keep the 4x carbs fed, right?
I'm trying to get things done to a finish of sorts....thanks for checking in chaps  :D
Offline Maritime
« Reply #183 on: Sep 16, 2016, 15:02:37 »
Make sure the battery can handle that, a lot of moto batteries can't take more than 1.5-2 amps without being damaged.  Glad to hear she runs!
Offline NoRiders
« Reply #184 on: Sep 16, 2016, 15:23:56 »
Ah, OK. The max is 25amps, but there's a 'min' setting as well. I can't find the 'min' amp rate though??
A review was from a motorbike mechanic who rated this unit....one fo the reasons I invested in it tbh.
I'm so pleased it ran...now just getting around to the last few jobs.
Offline NoRiders
« Reply #185 on: Sep 17, 2016, 10:31:28 »
You know when you connect the battery charger....plug it in and the lights come on.....well, that doesn't mean it's actually 'TURNED ON' and working.
I've been sitting like a chump waiting for the battery to charge only to notice I hadn't remembered to SWITCH THE BLOODY THING ON!!!  ::) >:(  :-[
In other new....the tank now fits on with the loom routed and tied down, so all good. Just need to drill out the rear mounting tab and find the flip cap mechanism which I have misplaced somewhere in the shit pit I call a garage.
Offline Northish
  • If you know what you're doing, you're not learning
« Reply #186 on: Sep 17, 2016, 13:00:30 »
Hey NoRiders - Liking the way the silencer ended up position-wise.  Looks like it will be outta the way in the twisties and give a little ground clearance if it gets off road.
Did you have to support its weight by fixing it to the bike somewhere or is it light enough that it won't need it?
« Last Edit: Sep 17, 2016, 13:04:04 by Northish »
Offline NoRiders
« Reply #187 on: Sep 17, 2016, 16:46:28 »
Yeah, it's worked out well, almost no need to consider changing or modifying it now it's on. The rear end has a bracket which bolts to the end of the footrest casting, you can see a single bolt holding it and the outline of the black bracket behind the casting in this image.
Had some time in the garage today, fiddly fiddly and doesn't look like much has been done, but I've managed to get the tank to fit around the loom/cables and modded the rear mount tab to suit the CBX mount. I'll source a larger penny washer but it hold OK as is.
Tank now sits just about right...pleased with how it turned out.
Had to fit the LEDs to the speedo mount and then sheath the tails and protect the connections and LED unit. I used VW door card witches hat grommets which worked a treat.
A smear of Vaseline will help keep the water off. It's a bit busy under there, but I'll tidy it as best I can, some of it will be hidden by the headlamp I hope. This was never going to be a super clean minimalist bike.
I rather like my view of the cockpit...
Here's a close up of the speedo and idiot lights, given I fucked up the size of the holes I'm pleased they turned out OK.
I arranged the colours according to Honda layout, YRGB to keep it authentic haha!
The bike started again today, but I have a misfire.....
Offline Alex jb
« Reply #188 on: Sep 17, 2016, 19:33:54 »
Looking great, a masterclass in making what you have, what you want.
Offline NoRiders
« Reply #189 on: Sep 17, 2016, 19:48:37 »
Gee thanx Alex. I'm pleased with the way it's finally turning out....bit different to what I started out to build, but not by much haha!
