2009 CR125AF Flat Tracker
chad.bakken
Hello. I put up an introduction post a while ago and got nothing soooo... Here's my build thread.
It started with a phone call. A buddy said he had bought a 2009 CRF450 and stole the engine for him J&M framer. I asked about the roller and he all but gave it to me. So there I was, with a complete 450 roller and no reason to have it.
I have raced hare scrambles since I was 4 years old and always had a dirt bike around. About three years ago I caught the flat track bug and bought a XR100 set up for the Maddog class. I out grew that quickly and moved to a '74 Rickman framer with a '73 CR250 Elsinore engine. There isn't much racing here in Va and I decided to sell the Rickman and get another regular dirt bike.
Then this roller showed up.
I raced the XR in the Maddog class along with the 0-200cc class. I like the 0-200 so decided to still with that class. I found a 1995 CR125 that was blown up and picked it up for a song.
I stripped out the engine and put the rest out back behind the shed
Once I had the engine out it and knew what I needed to do I needed to work on the suspension done before I could figure out the engine. I found a set of '87 gxsr750 forks for cheap and got to work.
I took the 450 triple clamps and 750 clamps. I pressed both stems out and had to machine the clamps. After machining and honing I pressed the 450 stem into the 750 clamps.
After the clamps were sorted I couldn't help but do a little mock up.
Next step was the front wheel.
Thanks! I appreciate it. I'll post more as I get photos saved to my phone.
Another photo of the forks mounted up.
I apologize in advance for any grammatical errors. I'm not very good at proof reading.
Thank you. I started the project in July and finished it last week. It was a fun yet stressful six months.
As for the front wheel I used the stock hub from the 125. I set it up in the lathe and tuned off the rotor lugs.
I used a Buchanan spoke kit and laced it to a 19" rear rim off a YZ250.
My son was a big help making sure I trued the wheel correctly.
Next I had to get the front wheel on the bike.
Mating the CR125 hub to the GSXR forks meant new spacers and axle were in order. Luckily at work you can make personal items after hours.
I made the axle out of 4140 steel
The spacers are 6061
And then came the handle bars. Being as the Suzuki used clip ons I had to figure something out for bar clamps. An open cnc machine and a couple lunch breaks later I had my clamps.
They took about two minutes a piece in the machine. I cut them apart on a cold saw.
I'm not a very good aluminum welder so I had the welder at work help me out.
Well after I had the clamps welded and put the bars on I was able to work on the rake and ride height.
I used my digital protractor and a floor jack. Again, my son was eager to help.
Here are all the numbers I got from the set up. I found a write up on setting your bike up for short tracks and got my numbers as close as I could.
Looking good! Your son is a lucky boy to have you get him involved with bike building :) I did the same with my son just as my dad did with me!
That's awesome. I grew up in my dads garage watching him fix our dirt bikes. He isn't a fabricator but is an excellent mechanic. He rebuilt the engine that's in this bike, along with all the bikes my brother and I blew up over the years. I learned a lot from him. My son wants to be a machinist like I am. That's makes me happy but I have mixed feelings about. There are many less stressful professions that earn way more money.
Once the numbers were in line I sent the stock shock out to be shortened and re-valved. To match the forks.
I made a little wooden strut to keep the rear end up and started playing with engine placement.
It amazes me that the swing arm pivot shaft and the rear engine mount were a perfect fit despite being 14 years apart. The 450 frame left a lot of room to play with but I had one major hurtle. The exhaust port.
That's great he wants to be a machinist, keep him interested! I did an apprenticeship in a fab/machine/welding shop and have never regretted it. I ended up getting a degree and working as a mechanical designer after that.
That exhaust port is quite a hurdle, do you have a plan yet?
Oh yeah! I figured out where the frame needed to be modified and started cutting.
I started with a 2 1/2" hole saw.
I cut out the rest and used a carbide burr set to clean it up.
I cut the pipe and rotated it to get it where it would fit and I could use the stock 450 mounting locations.
I got everything mocked up and took the frame to work. A little more grinding and making a filler panel didn't take to terribly long and the welder at work helped with the filler and adding a brace across the bottom of the frame.
Doesn't the service Honda 500AF move that whole piece up for the exhaust? I know you're not squeezing a cr500 in there but it seems like the concept would be the same. I know there are conversion kits floating around the net. http://www.ebay.com/itm/112260643043
Sent from my SAMSUNG-SM-G920A using DO THE TON mobile app
They rebuild the whole lower cradle. That was my initial plan but, being as I am not trying to mass produce or build more, making all the fixtures to do it wasn't worth it. The way I did it I didn't cut into any main structure or high stress area. Just the lower casting. With the added brace it will be just as strong as stock. I don't plan to make another. My next build will have a steel frame so I don't have to rely on other people to help.
I hadn't seen those kits before. Looks pretty neat. I tried to keep as much of the stock frame as possible. Just enough to get the pipe through. Plus with the 125 that's the only issue. There is a ton of clearance everywhere else. From what I have read Service Honda uses a 250F frame. I'm not sure of the size differences.
Well... I haven't added anything in a while and have been super busy with other things. So I decided to cut to the case and post up a few finished photos of the bike. I'm heading to South Carolina this weekend for the Sumter national enduro but making a pit stop in NC on Friday to run the bike and break the new engine in.
