www.townmoto.com
www.Moto-Madness.com
Author Topic: Sparck Moto FB-11 Presale  (Read 2794 times)
Online Sonreir
  • Moderator
  • Oregon
Re: Sparck Moto FB-11 Presale
« Reply #10 on: Feb 14, 2017, 18:30:35 »
Affordable.
Do you have a electrical schematic of how the device works?
I have a schematic we used to design the box, but I'm still working on the version that will be distributed with the box for the end-user. The diagram will include the purpose of all of the terminals and the corresponding fuse locations.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline AgentX
« Reply #11 on: Feb 23, 2017, 12:35:55 »
Awesome! Congrats; it's an impressive design and you worked your ass off to get it here.
Can you give a run-down on the specs for this thread?  How many circuits/relays, etc.?
"What's the use of having a motorcycle if you can't go tearing around staying out late?" Ralph asked reasonably.
Online Sonreir
  • Moderator
  • Oregon
« Reply #12 on: Feb 23, 2017, 12:48:56 »
Nine circuits, but three of the terminals are on a single circuit. 11 total power plugins (hence the name, FB-11).  Three of these connections are "always on", so you can hook up anything that might require power while the bike is off (some gauges, battery tender, etc).
There are three onboard relays, two are Single Throw (basically on/off switches) routed directly from the battery (this can help with high draw components such as the ignition coils). The other relay is Double Throw and is intended to be used for the headlight (high and low beam). This relay is basically always on when the bike is on, but swaps between it's two outputs. So your low beam would be on when the bike is, but then triggering the relay would swap the output over from the low beam to the high beam.
Additionally, each fused circuit has an LED to indicate if the circuit is complete. If the fuse blows, the LED goes out.
Offline Maritime
« Reply #13 on: Feb 23, 2017, 13:17:45 »
the fuse lights are great, I popped a fuse while monkeying with a circuit and it blinked out and I knew the fuse went.  Finished repairing the wire and then new fuse and all good again. Also there is a little blue LED that is always on to know the board has power. It lights my shop like a nightlight right now, bikes on a tender so no worries about drain and also Matt said it would take 250+ days for it to run down the battery.  I also used one of the always on for the after market gauge I bought and it was very easy to wire up. I managed to re-do my entire harness after the crash, the original was destroyed and it went really smooth.
« Last Edit: Feb 23, 2017, 13:21:38 by Maritime »
Offline eyhonda
« Reply #14 on: Mar 21, 2017, 11:52:27 »
Current capacity for the boards is design limited to 15 amps given a 50c rise in temp (copper temp) per terminal.    Relays are 15a on the NO terminals.
90 RC31 Hawk, parts collection phase.
72 CB175, cafe project.
15 CBR300r, tri-color.  My new daily ride.
Online Sonreir
  • Moderator
  • Oregon
« Reply #15 on: Jun 15, 2017, 23:52:27 »
AAANNNNNDDDD we finally have a manufacturer!
A sample is currently being produced and will be in my hands in the next couple of weeks. If everything checks out, we just need to get several grand together to get things started.
Thanks for the patience!
Online Sonreir
  • Moderator
  • Oregon
« Reply #16 on: Jul 18, 2017, 00:44:57 »
And we have our sample from the manufacturer!
Everything tests OK on this end. I've just shipped out it to eyhonda for further testing. Pending his approval, we're going to production on our first run.
Last call for the pre-sale!
Offline eyhonda
« Reply #17 on: Jul 18, 2017, 22:59:44 »
Looks really good, Matt! Can't wait to inspect it when it gets here.
Online Sonreir
  • Moderator
  • Oregon
« Reply #18 on: Jul 18, 2017, 23:04:56 »
The production version shouldn't be using the red LED. This was just a spare they had laying around and I said it would be fine to use.
Online Sonreir
  • Moderator
  • Oregon
« Reply #19 on: Jul 20, 2017, 23:50:52 »
And we've passed all our tests. I'm putting in the production order.
Last call for pre-orders!
