Hey guys,
Having some clutch related problems with my '76 CB360. Here's a little explanation...
So took it out this weekend and it was running/shifting fine then after about 15-20 mins of riding it at operating temp it started to get really hard to shift into first gear and near impossible to find neutral when coming to a stop. It was also super hard to shift out of first into second, I was having to ride out first gear much longer than usual and then really kick the bike into second then every gear after that felt fine. Then I came to a stop at an intersection and had the bike in first, since i couldnt get it into neutral, with the clutch pulled in and the bike started to move forward then all of the sudden it stalled out and so i pulled the clutch in to roll over to the side of the road and it wouldnt move, its like the clutch wasnt engaging properly. I pulled the clutch in again then finally managed to find neutral using my hand and proceeded to get off of the street. One factor that I'm assuming could be part of the issue is that my bike leaks a bit of oil, its either coming from the clutch pushrod seal or the shifter seal so I'm replacing those soon however does anyone know what is up with the clutch issue? I did adjust it a couple days prior to riding it so I'm hoping I might have just adjusted it wrong but figured I'd reach out to the forum and see if anyone could help me out.
Thanks in advance!
-Stu
Thanks in advance!
-Stu
