83scrambler
Here's the link to the schematic I used from Motofaccione's site.
http://www.motofiaccone.com/moto/39-cb360-cafe-racer/88-hiding-cafe-racer-batteries
Upon the multiple tests that I ran while the bike was not running but with ignition on, the lights worked fine, front and rear brake indicator worked fine.
Took it out for the maiden voyage and blew both the head light and tail light, although the brake light is still good as its not a continuous running light.
I am wondering if thereneeds to be some fusing or a diode put inplace to protest the lighting system based off the schematic shown. I wired this schmatic up specifically with no shortcuts or modifications other than running a single battery instead of the three.
Does this indicate that either a recitifer or regulator is bad?
I woudl appreciate any input that you may have as I'm currently lost on this. I am going to do a quick run down on the rectifier, I have not gotten my hands on a tried and true regulator test yet.
Thanks!
Justin
Thanks!
Justin
