Eric P
Active Member
Well, I finally decided it's time to start from scratch and rewire my GT380. The stock harness has tangles of wire all balled up in the headlight, and I have to hunt down a couple of electrical gremlins.
Anyway, I've been wanting to get rid of this rusty rectifier for a while. I figured now would be the time to switch it out and clean up this mess. Is it possible to replace the regulator and rectifier with one unit? It seems like it shouldn't be too hard, but I'm having trouble figuring out the wiring in my head. ???
Here is a link to the original wiring diagram:
http://www.ozebook.com/compendium/suzi/models/G380wd.gif
I get that the yellow wires from the alternator will go to the yellow wires on the R/R and that the red wire on the R/R goes to the battery.
Is the green wire on the R/R a ground wire, or is it just grounded through the mounting bolts? Why do only some R/Rs have a black wire... and what does that wire go to? I also have a dark green wire coming out of my alternator that currently goes to the regulator. Where should this wire go if I switch to a combined unit? Can anyone tell me what wires I need to make sure a R/R has before I buy one for my bike?
Sorry for all the questions, but this electrical stuff is grouped next to sticking pins into dolls in my brain. It just doesn't make much sense to me. Thanks a ton.
Eric
Eric
