gsdapollo
Hey everyone, hope you all can help me out as I really want to get this pain in my
running... Bike has been sitting for a year, charged the battery up three weeks ago, bike turned over just fine. Spent the next week getting everything I need to finish her, went to start it and nothing happened. Battery is showing 12 volts, so thats good. If I short the - and + terminals on the starter solenoid, the starter turns right over, so the starter works and the battery has enough juice to turn it. I disassembled the starter button and kill switch completely, cleaned and greased all terminals, and reassembled. Continuity tests on kill switch shows nothing with open(Off), beeps when closed (Run). Continuity tests on starter button shows the same. Continuity tests on all wires checked out fine, no breaks anywhere. All connections were cleaned and checked, everything was fine. Fuses are all good. So I started thinking beyond all this, I checked for power coming from the ignition when the key was turned on, nothing. So power isnt even getting to the ignition. So I started to check the schematics to see how power flowed through the whole bike and I just need someone to check me on this:
All power comes from the battery obviously. When the ignition key is turned on, the circuit is closed between the battery, the ignition and the rest of the bike. Now speaking strictly of the starting system, when the ignition is turn on, power flows from the battery, through the starter solenoid, through the 4-pin connector on the solenoid, through the ignition, through the fuse box, then through the kill switch (assuming its in the Run position), through the starter button (assuming its being engaged) back into the starter solenoid and down into the starter motor. Does this sound right? The reason I ask is because nothing works on my bike now, yet everything worked just fine before this starting problem. So if my explanation is correct, then technically, if the solenoid is fried or if the 4-pin connector is removed, then no power would be able to reach the rest of the bike. Therefore, making the solenoid the culprit to the pain currently residing in my ass... Thanks for the help!!
